Saltar al contenido principal
Nexus 9 Front Facing Camera Replacement
Qué necesitas
  1. Nexus 9 Front Facing Camera Replacement, Rear Case: paso 1, imagen 1 de 3 Nexus 9 Front Facing Camera Replacement, Rear Case: paso 1, imagen 2 de 3 Nexus 9 Front Facing Camera Replacement, Rear Case: paso 1, imagen 3 de 3
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
    • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
  2. Nexus 9 Front Facing Camera Replacement, Front Facing Camera: paso 2, imagen 1 de 1
    • Use a spudger to disconnect the front-facing camera ZIF connector.
    • Use a pair of tweezers to gently lift the front-facing camera up from the motherboard.
Conclusión
Una persona más ha completado esta guía.
Geoff Wacker
Miembro Desde 09/30/13
89,846 Reputación
89 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 749
