Saltar al contenido principal
Nexus 7 Speaker Cable Replacement
Sólo Prerrequisito
Esta guía solo debería usarse como prerrequisito para otras guías. Por tanto, estará incompleta.
Qué necesitas
  1. Nexus 7 Speaker Cable Replacement, Speaker Cable: paso 1, imagen 1 de 1
    • Peel back the copper ESD shielding covering the bottom of the motherboard.
    • Do not try to remove the copper shielding, as it is still attached underneath the battery.
    • If you're just replacing the micro usb charge port, there is no need to peel back the copper heatsink like in the photo, the speaker assembly can simply be moved out of the way once unscrewed. If the speakers are to be replaced simply peel back the bottom corner to expose the speaker connection. Leave the rest of the heatsink shield alone.
  2. Nexus 7 Speaker Cable Replacement: paso 2, imagen 1 de 1
    • Using the tip of a spudger, push the speaker cable straight out of its socket on the motherboard.
Conclusión
Brett Hartt
Miembro Desde 04/12/10
127,941 Reputación
143 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
136 Miembros
17,298 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 7
Todo El Tiempo: 42
