Saltar al contenido principal
Nexus 6P Daughterboard/Charging Port Replacement
Qué necesitas
Resumen del Video
  1. Nexus 6P Daughterboard/Charging Port Replacement, Daughterboard/Charging Port: paso 1, imagen 1 de 2 Nexus 6P Daughterboard/Charging Port Replacement, Daughterboard/Charging Port: paso 1, imagen 2 de 2
    • Remove SIM card tray.
  2. Nexus 6P Daughterboard/Charging Port Replacement: paso 2, imagen 1 de 3 Nexus 6P Daughterboard/Charging Port Replacement: paso 2, imagen 2 de 3 Nexus 6P Daughterboard/Charging Port Replacement: paso 2, imagen 3 de 3
    • Heat up back glass panel.
    • Use hobby knife to open a gap and cut the fierce sticker underneath rear glass panel.
    • The back glass panel is easily shattered and the adhesive underneath is fierce. So be careful to pry this part.
  3. Nexus 6P Daughterboard/Charging Port Replacement: paso 3, imagen 1 de 3 Nexus 6P Daughterboard/Charging Port Replacement: paso 3, imagen 2 de 3 Nexus 6P Daughterboard/Charging Port Replacement: paso 3, imagen 3 de 3
    • Heat up bottom plastic panel.
    • Use hobby knife to open a gap and insert guitar picks to cut adhesive underneath.
  4. Nexus 6P Daughterboard/Charging Port Replacement: paso 4, imagen 1 de 3 Nexus 6P Daughterboard/Charging Port Replacement: paso 4, imagen 2 de 3 Nexus 6P Daughterboard/Charging Port Replacement: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    Comprar
    • Twist off 6 Phillips screws together.
    • Insert guitar picks and plastic opening tool to separate front assembly from back cover.
    • Attention: These two parts fit tightly.It is the toughest part to separate. You can also try using heavy-duty suction cup to disassemble them.
  5. Nexus 6P Daughterboard/Charging Port Replacement: paso 5, imagen 1 de 3 Nexus 6P Daughterboard/Charging Port Replacement: paso 5, imagen 2 de 3 Nexus 6P Daughterboard/Charging Port Replacement: paso 5, imagen 3 de 3
    • Unscrew one Phillips screw.
    • Remove metal bracket securing flex contactors.
    • Release 3 flex contactors and remove it .
    • This flex is used to connect motherboard and daughterboard.
  6. Nexus 6P Daughterboard/Charging Port Replacement: paso 6, imagen 1 de 3 Nexus 6P Daughterboard/Charging Port Replacement: paso 6, imagen 2 de 3 Nexus 6P Daughterboard/Charging Port Replacement: paso 6, imagen 3 de 3
    • Disconnect signal cable contactor and twist off one Phillips screw.
    • Remove daughterboard.
  7. Nexus 6P Daughterboard/Charging Port Replacement: paso 7, imagen 1 de 1
    • Here is the daughterboard. The charging port is attached here.
Conclusión
23 personas más completaron esta guía.
Witrigs
Miembro Desde 11/24/15
69,647 Reputación
378 Guías creadas
13 comentarios
Do you know the part number of the daughterboard, or where I can buy a replacement?
Ezequiel Arneodo - Contestar
Global Direct Parts seems to have OEM parts. Don't go with eBay and stuff. The ones I saw are cheap knockoffs that don't work right (even when they say OEM).
Sunny Wu -
Do we need more adhesive or everything will stick back with heat?
Will Taylor - Contestar
I have replaced my battery. You most likely will need more adhesive. I just plan on using some double sided tape as the original glue was too tough in case I have to open it again. You can just buy a case for it after. It will keep everything nice and tight on there.
Sunny Wu -
To replace the daugherboard, step #5 can largely be skipped - just remove the cable from the daugherboard and move on to step #6. This phone is a true PITA to take apart.
ashlux - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 10
Todo El Tiempo: 18,231
