Saltar al contenido principal
Nexus 5X Rear Panel Replacement
Qué necesitas
  1. Nexus 5X Rear Panel Replacement, SIM Card Tray: paso 1, imagen 1 de 3 Nexus 5X Rear Panel Replacement, SIM Card Tray: paso 1, imagen 2 de 3 Nexus 5X Rear Panel Replacement, SIM Card Tray: paso 1, imagen 3 de 3
    • Insert a SIM card ejection tool into the hole on the SIM card tray, located on the left edge of the phone.
    • Press in to eject the SIM card tray.
    • Remove the SIM card tray.
  2. Nexus 5X Rear Panel Replacement, Rear Panel: paso 2, imagen 1 de 3 Nexus 5X Rear Panel Replacement, Rear Panel: paso 2, imagen 2 de 3 Nexus 5X Rear Panel Replacement, Rear Panel: paso 2, imagen 3 de 3
    • Place an opening pick in the opening of the SIM card tray slot and twist it sideways to release the first plastic clip that holds the rear panel in its place.
    • Slide the opening pick around the top edge of the phone to release the plastic clips that secure the rear panel.
  3. Nexus 5X Rear Panel Replacement: paso 3, imagen 1 de 3 Nexus 5X Rear Panel Replacement: paso 3, imagen 2 de 3 Nexus 5X Rear Panel Replacement: paso 3, imagen 3 de 3
    • Continue to slide the opening pick around all sides of the phone to release all clips that secure the rear panel.
  4. Nexus 5X Rear Panel Replacement: paso 4, imagen 1 de 2 Nexus 5X Rear Panel Replacement: paso 4, imagen 2 de 2
    • Tilt the opening pick to lift the rear panel a little bit.
    • There are two more plastic clips next to the fingerprint sensor. Release them by gently pulling the rear panel.
    • Remove the rear panel.
Conclusión
Repair didn’t go as planned? Check out our Nexus 5X Answers community for troubleshooting help.
26 personas más completaron esta guía.
Dominik Schnabelrauch
Miembro Desde 11/23/16
203,299 Reputación
682 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
16,817 Guías creadas
Un comentario
Bonjour,
Est-ce que vous arriveriez à m'indiquer l'espace disponible (en mm) entre le cache et la batterie svp?
Merci!
Lucas Marti - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 8,707
