Introducción
Use this guide to remove the motherboard in the Nexus 5X.
Some guide images will show the battery already removed from the phone. You do not need to remove the battery for this procedure
You’ll need replacement adhesive to reattach components when reassembling the device.
Qué necesitas
Insert a SIM card ejection tool into the hole on the SIM card tray, located on the left edge of the phone.
Press in to eject the SIM card tray.
Remove the SIM card tray.
Place an opening pick in the opening of the SIM card tray slot and twist it sideways to release the first plastic clip that holds the rear panel in its place.
Slide the opening pick around the top edge of the phone to release the plastic clips that secure the rear panel.
Use the edge of a spudger to pry up and disconnect the battery flex cable located at the bottom right of the motherboard.
Paso 11 Motherboard Assembly
Aviso: los pasos 11-14 provienen de una guía que está marcada como "En progreso".
Use an iOpener to loosen the adhesive beneath the rear facing camera. Place the iOpener across the top part of the phone for about 30 seconds.
Use the flat end of a spudger to pry up the rear-facing camera connector from the motherboard.
Carefully remove the rear facing camera.
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
To reassemble your device, follow these instructions in reverse order. During reassembly apply new adhesive where it’s necessary.
Repair didn’t go as planned? Check out our Nexus 5X Answers community for troubleshooting help.
61 personas más completaron esta guía.
40 comentarios
Anyone with the bootloop problem has been successful on returning the 5X to life by replacing the motherboard?
that's a stupid question. new motherboard means new operating system. maybe you should just use fastboot and flash stock firmware on your phone easy
where can I get a new motherboard at?????
in most 'google image boot' issues, it is a hardware issue, not software. besides, the phone will not allow a bootloader option.
yes …….and its the only way after bootloop
