Saltar al contenido principal
Nexus 4 Power and Volume Button Replacement
Qué necesitas
  1. Nexus 4 Power and Volume Button Replacement, Back Cover: paso 1, imagen 1 de 2 Nexus 4 Power and Volume Button Replacement, Back Cover: paso 1, imagen 2 de 2
    Herramienta utilizada en este paso:
    SIM Card Eject Tool
    $2.99
    • Power off the phone, by long-pressing the power button and touching Power off.
    • Remove the SIM tray using the SIM Card Eject Tool.
    • This step is required in order to remove the back case.
  2. Nexus 4 Power and Volume Button Replacement: paso 2, imagen 1 de 1
    T5 Torx Screwdriver
    $5.49
  3. Nexus 4 Power and Volume Button Replacement: paso 3, imagen 1 de 3 Nexus 4 Power and Volume Button Replacement: paso 3, imagen 2 de 3 Nexus 4 Power and Volume Button Replacement: paso 3, imagen 3 de 3
    • Gently open the back case by prying along the edge of the cover, starting at a corner of the phone and circling around the phone using a plastic opening tool.
    • The opening process may take a few minutes. The plastic will make a light snapping noise as the back cover separates from the rest of the phone.
  4. Nexus 4 Power and Volume Button Replacement, Power and Volume Button: paso 4, imagen 1 de 2 Nexus 4 Power and Volume Button Replacement, Power and Volume Button: paso 4, imagen 2 de 2
    • Holding the back case, gently push the power button in towards the center of the phone using a spudger.
  5. Nexus 4 Power and Volume Button Replacement: paso 5, imagen 1 de 3 Nexus 4 Power and Volume Button Replacement: paso 5, imagen 2 de 3 Nexus 4 Power and Volume Button Replacement: paso 5, imagen 3 de 3
    • To remove the volume button, push the button in towards the center of the phone using a spudger.
Conclusión
16 personas más completaron esta guía.
Kaitlyn Jones
Miembro Desde 01/27/13
4,964 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 3-32, Amido Winter 2013 Miembro de Cal Poly, Team 3-32, Amido Winter 2013
CPSU-AMIDO-W13S3G32
Miembros de 4
8 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 29,988
