Saltar al contenido principal
Nexus 4 Plastic Midframe Replacement
Qué necesitas
    • Power off the phone, by long-pressing the power button and touching Power off.
    • Remove the SIM tray using the SIM Card Eject Tool.
    • This step is required in order to remove the back case.
  1. Nexus 4 Plastic Midframe Replacement: paso 3, imagen 1 de 3 Nexus 4 Plastic Midframe Replacement: paso 3, imagen 2 de 3 Nexus 4 Plastic Midframe Replacement: paso 3, imagen 3 de 3
    • Gently open the back case by prying along the edge of the cover, starting at a corner of the phone and circling around the phone using a plastic opening tool.
    • The opening process may take a few minutes. The plastic will make a light snapping noise as the back cover separates from the rest of the phone.
  2. Nexus 4 Plastic Midframe Replacement, Battery: paso 4, imagen 1 de 2 Nexus 4 Plastic Midframe Replacement, Battery: paso 4, imagen 2 de 2
    • Remove the two 1.8 mm Phillips screws holding down the battery connector.
    • Using a plastic opening tool, disconnect the battery cable from its socket on the motherboard.
    • Remove the blue tape that secures the white antenna cable to the battery.
    • Using a spudger, carefully disconnect the white antenna cable.
    • Carefully pry the battery out with a Plastic Opening Tool, starting at the top left-hand corner and working down towards the bottom right-hand corner.
    • If necessary, you can also use a plastic card to separate the battery from the metal midframe.
    • The battery is securely glued to the phone. When reinstalling the battery, press the battery firmly against the adhesive strip.
  3. Nexus 4 Plastic Midframe Replacement, Plastic Midframe: paso 6, imagen 1 de 3 Nexus 4 Plastic Midframe Replacement, Plastic Midframe: paso 6, imagen 2 de 3 Nexus 4 Plastic Midframe Replacement, Plastic Midframe: paso 6, imagen 3 de 3
    • Remove the nine 4.6 mm Phillips #000 screws. Gently lift out the plastic cover.
    • The midframe is held in with two clips, one at either side. Use a plastic spudger to release each side and gently lift up and away.
Conclusión
7 personas más completaron esta guía.
Kaitlyn Jones
Miembro Desde 01/27/13
4,952 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 3-32, Amido Winter 2013 Miembro de Cal Poly, Team 3-32, Amido Winter 2013
CPSU-AMIDO-W13S3G32
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 10,962
