Saltar al contenido principal
Nextplay NP109CR Speakers Replacement
Qué necesitas
  1. Nextplay NP109CR Speakers Replacement, Speakers: paso 1, imagen 1 de 1
    • Turn the device over so it is upside-down.
  2. Nextplay NP109CR Speakers Replacement: paso 2, imagen 1 de 1
    • Unscrew the 4 screws closest to the screen.
  3. Nextplay NP109CR Speakers Replacement: paso 3, imagen 1 de 1
    • Flip over the device so it is right side up.
  4. Nextplay NP109CR Speakers Replacement: paso 4, imagen 1 de 1
    • Unscrew the 2 screws on the top of the device, next to the docking plug.
  5. Nextplay NP109CR Speakers Replacement: paso 5, imagen 1 de 1
    • Take off top piece by using slight force and pulling off.
  6. Nextplay NP109CR Speakers Replacement: paso 6, imagen 1 de 1
    • Unscrew the button board with smaller screwdriver.
  7. Nextplay NP109CR Speakers Replacement: paso 7, imagen 1 de 1
    • Lift off the button board.
  8. Nextplay NP109CR Speakers Replacement: paso 8, imagen 1 de 1
    • Unscrew all visible of the screws on the black logic board cover with the larger screwdriver.
  9. Nextplay NP109CR Speakers Replacement: paso 9, imagen 1 de 1
    • Lift the screen vertically straight up.
    • As you do this the logic board should move off with it.
  10. Nextplay NP109CR Speakers Replacement: paso 10, imagen 1 de 1
    • Flip the screen and the logic board over to the right side.
  11. Nextplay NP109CR Speakers Replacement: paso 11, imagen 1 de 1
    • Pull out the white plug that goes from the speakers to the logic board.
    • Then plug back in making sure it is completely connected.
Conclusión
Michelle Read
Miembro Desde 09/26/12
1 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 7-50, Forte Fall 2012 Miembro de Cal Poly, Team 7-50, Forte Fall 2012
CPSU-FORTE-F12S7G50
5 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 402
