Introducción
It is important to note that this guide requires the use of a soldering iron. Be sure you familiarize yourself on how to use a soldering iron.
Qué necesitas
Insert the plastic opening tool into the middle of the bottom edge of the device. The tool should be inserted within the seam between the back and front covers.
Slide the opening tool to the right and slowly continue to separate the back cover from the device.
To reassemble your device, follow these instructions in reverse order, being careful when re-soldering the contacts back into place.
Una persona más ha completado esta guía.
