Saltar al contenido principal
Nextbook Premium 7SE Battery Replacement
Qué necesitas
  1. Nextbook Premium 7SE Battery Replacement, Back Cover: paso 1, imagen 1 de 3 Nextbook Premium 7SE Battery Replacement, Back Cover: paso 1, imagen 2 de 3 Nextbook Premium 7SE Battery Replacement, Back Cover: paso 1, imagen 3 de 3
    • Insert the plastic opening tool into the middle of the bottom edge of the device. The tool should be inserted within the seam between the back and front covers.
    • Slide the opening tool to the right and slowly continue to separate the back cover from the device.
    • Avoid prying on the buttons, as they are easily damaged.
  2. Nextbook Premium 7SE Battery Replacement: paso 2, imagen 1 de 1
    • Pull the cover off of the device once about three quarters of the cover has been pried open using the plastic opening tool.
  3. Nextbook Premium 7SE Battery Replacement, Battery: paso 3, imagen 1 de 1
    • Remove masking tape from the battery.
  4. Nextbook Premium 7SE Battery Replacement: paso 4, imagen 1 de 3 Nextbook Premium 7SE Battery Replacement: paso 4, imagen 2 de 3 Nextbook Premium 7SE Battery Replacement: paso 4, imagen 3 de 3
    • Pry the battery from the base using the nylon spudger and move it away from the motherboard.
    • Handle the battery with care to avoid damaging it.
  5. Nextbook Premium 7SE Battery Replacement: paso 5, imagen 1 de 3 Nextbook Premium 7SE Battery Replacement: paso 5, imagen 2 de 3 Nextbook Premium 7SE Battery Replacement: paso 5, imagen 3 de 3
    • De-solder the three contact points and remove the battery.
    • See the following guide for instructions on how to solder. Cómo soldar y desoldar conexiones
    • Use caution when operating the soldering iron.
Conclusión
To reassemble your device, follow these instructions in reverse order, being careful when re-soldering the contacts back into place.
Una persona más ha completado esta guía.
Equipo
Baylor, Team 4-1, Williams Fall 2016 Miembro de Baylor, Team 4-1, Williams Fall 2016
BU-WILLIAMS-F16S4G1
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 724
