Saltar al contenido principal
Nextbook NX008HD8G Battery Replacement
Qué necesitas
  1. Nextbook NX008HD8G Battery Replacement, Back Panel: paso 1, imagen 1 de 2 Nextbook NX008HD8G Battery Replacement, Back Panel: paso 1, imagen 2 de 2
    • Using your finger, open the plastic tab to the right of the rear-facing camera.
    • Wedge your fingernail in between the back panel and the plastic tab and pull the plastic tab towards your body.
  2. Nextbook NX008HD8G Battery Replacement: paso 2, imagen 1 de 3 Nextbook NX008HD8G Battery Replacement: paso 2, imagen 2 de 3 Nextbook NX008HD8G Battery Replacement: paso 2, imagen 3 de 3
    • Using your finger, remove the SD card by pressing down on top of it (toward the bottom of the device) until you hear a clicking sound.
    • Once the card pops out, use your finger to pull the card completely out of the SD card slot.
  3. Nextbook NX008HD8G Battery Replacement: paso 3, imagen 1 de 3 Nextbook NX008HD8G Battery Replacement: paso 3, imagen 2 de 3 Nextbook NX008HD8G Battery Replacement: paso 3, imagen 3 de 3
    • Remove the 5 mm screw using the Phillips PH00 bit in the iFixit metal Screwdriver.
  4. Nextbook NX008HD8G Battery Replacement: paso 4, imagen 1 de 3 Nextbook NX008HD8G Battery Replacement: paso 4, imagen 2 de 3 Nextbook NX008HD8G Battery Replacement: paso 4, imagen 3 de 3
    • Use the plastic opening tool to separate the back panel by carefully sliding the narrow end of the tool between the front glass and back panel.
    • Use a second plastic opening tool to help pry the front glass from the back panel.
    • You will hear some cracking sounds when separating the front glass from the back panel. That is okay! That is the back panel latches releasing the front glass.
  5. Nextbook NX008HD8G Battery Replacement: paso 5, imagen 1 de 2 Nextbook NX008HD8G Battery Replacement: paso 5, imagen 2 de 2
    • Use your hands to completely separate the rest of the front glass from the back panel.
    • Do not to pull the device apart with too much force. If you do, you may break or bend the back panel.
  6. Nextbook NX008HD8G Battery Replacement, Battery: paso 6, imagen 1 de 3 Nextbook NX008HD8G Battery Replacement, Battery: paso 6, imagen 2 de 3 Nextbook NX008HD8G Battery Replacement, Battery: paso 6, imagen 3 de 3
    • Remove yellow tape with a black edge that covers the red, white and black wires.
    • The yellow tape with a black edge is safe to remove completely.
  7. Nextbook NX008HD8G Battery Replacement: paso 7, imagen 1 de 1
    • Remove the white masking tape covering the red white and black wires.
  8. Nextbook NX008HD8G Battery Replacement: paso 8, imagen 1 de 1
    • Desolder the red, white and black wires on the left side of the motherboard.
  9. Nextbook NX008HD8G Battery Replacement: paso 9, imagen 1 de 1
    • Use the flat end of the spudger to carefully separate the smaller, silver battery square from the digitizer.
    • The battery is very malleable, do not try to take it all off at once.
  10. Nextbook NX008HD8G Battery Replacement: paso 10, imagen 1 de 3 Nextbook NX008HD8G Battery Replacement: paso 10, imagen 2 de 3 Nextbook NX008HD8G Battery Replacement: paso 10, imagen 3 de 3
    • Use the flat end of the spudger to carefully separate the large battery from the digitizer.
Conclusión
4 personas más completaron esta guía.
Philip Gai
Miembro Desde 09/22/15
792 Reputación
3 Guías creadas
Equipo
Baylor, Team 10-15, Williams Fall 2015 Miembro de Baylor, Team 10-15, Williams Fall 2015
BU-WILLIAMS-F15S10G15
3 Miembros
8 Guías creadas
3 comentarios
Clear & concise. Nice job! Even I could follow it!! ;-)
intessol - Contestar
Excellent guide, easy to follow, very concise, very good photographs. Thank you
ken fukushima - Contestar
Donde puedo encontrar una batería
Lauraelena - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 19
Todo El Tiempo: 6,213
