Saltar al contenido principal
Nextbook NEXT7P12-8G Camera Replacement
Qué necesitas
  1. Nextbook NEXT7P12-8G Camera Replacement, Camera: paso 1, imagen 1 de 1
    • Use the plastic opening tool to pry apart the front and back covers of the Nextbook
    • Continue prying until the front and back covers are completely separated. Use the suction cup if necessary to pull apart
    • We recommend using an extra plastic opening tool to maintain your opening
  2. Nextbook NEXT7P12-8G Camera Replacement: paso 2, imagen 1 de 1
    • Once the front and back covers have been separated, set the back cover down and examine the interior of the Nextbook
    • Remove the various pieces of masking tape
  3. Nextbook NEXT7P12-8G Camera Replacement: paso 3, imagen 1 de 1
    • Carefully peel the battery pack off, starting from the outer edges
    • It is held down by an adhesive going diagonally across the back
    • Removing the battery will allow you to access the screws holding the chip in place
  4. Nextbook NEXT7P12-8G Camera Replacement: paso 4, imagen 1 de 1
    • Use a 4.0 bit screwdriver to remove the screws from the chip
  5. Nextbook NEXT7P12-8G Camera Replacement: paso 5, imagen 1 de 1
    • Remove the entire chip by severing small adhesive strips along the edges and pulling the chip away from the frame
    • Carefully peel away the black tape with copper detail that is holding the chip to the device
  6. Nextbook NEXT7P12-8G Camera Replacement: paso 6, imagen 1 de 1
    • Locate the camera
    • The camera will be a small black square directly behind the camera lens visible on the front side of the Nextbook
    • Pry the camera out of the front cover with the plastic opening tool
  7. Nextbook NEXT7P12-8G Camera Replacement: paso 7, imagen 1 de 1
    • Replace with a spare camera piece
Conclusión
Grace Cho
Miembro Desde 09/29/15
3 Reputación
1 Guía escrita
Equipo
Ohio State, Team 2-2, Garvin Fall 2015 Miembro de Ohio State, Team 2-2, Garvin Fall 2015
OSU-GARVIN-F15S2G2
3 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 10
Todo El Tiempo: 802
