Saltar al contenido principal
Nextbook NEXT7P12-8G Battery Replacement
Qué necesitas
  1. Nextbook NEXT7P12-8G Battery Replacement, Introduction: paso 1, imagen 1 de 3 Nextbook NEXT7P12-8G Battery Replacement, Introduction: paso 1, imagen 2 de 3 Nextbook NEXT7P12-8G Battery Replacement, Introduction: paso 1, imagen 3 de 3
    • Time to gram the trusty Ifixit Kit
    • Always properly ground yourself when working on small electronics..
  2. Nextbook NEXT7P12-8G Battery Replacement, Sliding off the back wall: paso 2, imagen 1 de 3 Nextbook NEXT7P12-8G Battery Replacement, Sliding off the back wall: paso 2, imagen 2 de 3 Nextbook NEXT7P12-8G Battery Replacement, Sliding off the back wall: paso 2, imagen 3 de 3
    • Picture one and two: Seperate back wall and blue mid frame. You are releasing about 8 or 10 clips accross the top.
    • Picture three : Lay tablet flat and lift at camera side, while sliding the back wall away from you. This will keep you from breaking the clips around the keyboard docking area.
  3. Nextbook NEXT7P12-8G Battery Replacement, Battery access: paso 3, imagen 1 de 3 Nextbook NEXT7P12-8G Battery Replacement, Battery access: paso 3, imagen 2 de 3 Nextbook NEXT7P12-8G Battery Replacement, Battery access: paso 3, imagen 3 de 3
    • Picture 1 : Now your in the beast
    • Picture 2 : First you want to peel back this tape and expose the battery connector. Remove the battery connector before anything else.
    • Picture 2: Next remove the ZIF connector directly underneath of the battery connector.
    • Picture 3 : Finally remove the 2 ZIF connectors at the bottom of the battery. These cameras can be pulled out of your way to have access to the battery
  4. Nextbook NEXT7P12-8G Battery Replacement, Battery removal: paso 4, imagen 1 de 1
    • Picture 1: Once the battery is free you will want to apply heat by either a hot plate, or a heat gun, to ease the removal of it. Only use FLAT ifixit plastic pry picks. DANGER: Puncturing battery can lead to fire, damage to your device, or even personal injury. PLEASE BE CAREFUL and Happy fixing
    • ifixit and the creator of this walthrough is not responsible for any damages to your device or self. All repairs are done at your own risk
    • Once battery is removed, follow these steps in reverse to reassemble.
Conclusión
Una persona más ha completado esta guía.
David Kyzer
Miembro Desde 07/27/18
208 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 10
Todo El Tiempo: 895
