Saltar al contenido principal
Nextbook Flexx 10 Back Cover Replacement
Qué necesitas
  1. Nextbook Flexx 10 Back Cover Replacement, Back Cover: paso 1, imagen 1 de 2 Nextbook Flexx 10 Back Cover Replacement, Back Cover: paso 1, imagen 2 de 2
    • To begin, turn off the power to the device and remove the screen from the keyboard.
    • Open the 2-in-1, and hold the screen.
    • Press the silver button at the top of the keyboard.
    • When the screen lifts up, gently lift the screen away from the keyboard.
  2. Nextbook Flexx 10 Back Cover Replacement: paso 2, imagen 1 de 3 Nextbook Flexx 10 Back Cover Replacement: paso 2, imagen 2 de 3 Nextbook Flexx 10 Back Cover Replacement: paso 2, imagen 3 de 3
    • You may use your fingers, or a spudger. Be careful not to break your cover OR your fingernail. Removing the cover requires good judgement.
    • The goal is to separate the black from the silver. Start in a corner, or a flat edge -- whichever works best for you. Remember to not use too much force.
    • Once you start the initial separation, keep going until you free one edge. The goal now is to free three edges of the rectangle.
    • If your progress stops on one side of the rectangle, go to the other side and try there.
  3. Nextbook Flexx 10 Back Cover Replacement: paso 3, imagen 1 de 2 Nextbook Flexx 10 Back Cover Replacement: paso 3, imagen 2 de 2
    • Gently pull the back cover from the screen assembly.
    • Keep the plastic cover close. It's great for holding screws!
    • When putting the cover back on, press firmly around to outside edge with the screen facing down on a flat, debris-free surface.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 20
Todo El Tiempo: 1,100
