Saltar al contenido principal
Nextbook Flexx 10 Camera Replacement
Qué necesitas
  1. Nextbook Flexx 10  Camera Replacement, Front and Rear Camera: paso 1, imagen 1 de 3 Nextbook Flexx 10  Camera Replacement, Front and Rear Camera: paso 1, imagen 2 de 3 Nextbook Flexx 10  Camera Replacement, Front and Rear Camera: paso 1, imagen 3 de 3
    • Remove the top section by pushing the middle button in the center of the base and lift on the screen.
  2. Nextbook Flexx 10  Camera Replacement: paso 2, imagen 1 de 3 Nextbook Flexx 10  Camera Replacement: paso 2, imagen 2 de 3 Nextbook Flexx 10  Camera Replacement: paso 2, imagen 3 de 3
    • Remove the black back panel of the screen.
  3. Nextbook Flexx 10  Camera Replacement: paso 3, imagen 1 de 2 Nextbook Flexx 10  Camera Replacement: paso 3, imagen 2 de 2
    • Place the panel screen down.
    • Identify the cameras at the top center.
  4. Nextbook Flexx 10  Camera Replacement: paso 4, imagen 1 de 3 Nextbook Flexx 10  Camera Replacement: paso 4, imagen 2 de 3 Nextbook Flexx 10  Camera Replacement: paso 4, imagen 3 de 3
    • Find the front camera.
    • Follow the gold strip to where it connects to the device.
    • There is a black piece that is holding the gold strip. Flip this up to release the camera.
    • Follow bullets above for the rear facing camera.
  5. Nextbook Flexx 10  Camera Replacement: paso 5, imagen 1 de 2 Nextbook Flexx 10  Camera Replacement: paso 5, imagen 2 de 2
    • Insert new camera into each slot, make connections, and close the black flap.
    • Snap back panel back onto the back of the screen.
    • Put screen and the keyboard back together.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 305
