Introducción
You will need a thin durable tool to get the back cover off first. A guitar pick works well if you don't have a plastic opening tool. The parts are very delicate, so use caution when removing the back cover and inner parts.
Qué necesitas
Use the plastic opening tool to remove the back cover. Carefully slide the tool between the front glass and back cover.
Slide the tool along the edge to work the back cover off.
Use a small Phillips screwdriver to remove the 0.116 inch screw holding the red and black wires in place on the inside of the back cover.
Una persona más ha completado esta guía.
