Saltar al contenido principal
Nextbook 8 Speaker Replacement
Qué necesitas
  1. Nextbook 8 Speaker Replacement, Battery: paso 1, imagen 1 de 2 Nextbook 8 Speaker Replacement, Battery: paso 1, imagen 2 de 2
    • Use the plastic opening tool to remove the back cover. Carefully slide the tool between the front glass and back cover.
    • Slide the tool along the edge to work the back cover off.
    • It helps to have an extra tool to stick in the gap and keep the back cover separated from the glass as you slide the other tool.
  2. Nextbook 8 Speaker Replacement: paso 2, imagen 1 de 2 Nextbook 8 Speaker Replacement: paso 2, imagen 2 de 2
    • Remove the tape covering the motherboard.
    • Remove the silver tape holding the white ribbon cables to the battery.
  3. Nextbook 8 Speaker Replacement: paso 3, imagen 1 de 2 Nextbook 8 Speaker Replacement: paso 3, imagen 2 de 2
    • Use a spudger to carefully disconnect the battery connector from the motherboard.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  4. Nextbook 8 Speaker Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Use a spudger to lift up the black bar on the two ZIF connectors located above the battery.
    • Pull the ribbon cables out of the connectors with tweezers or two fingers.
  5. Nextbook 8 Speaker Replacement: paso 5, imagen 1 de 2 Nextbook 8 Speaker Replacement: paso 5, imagen 2 de 2
    • Using the flat end of a spudger, carefully work the spudger under the battery, lifting it off of the device.
    • The battery is very malleable, so do not try to pull it off all at once.
  6. Nextbook 8 Speaker Replacement, Speaker: paso 6, imagen 1 de 1
    • Use a small Phillips screwdriver to remove the 0.116 inch screw holding the red and black wires in place on the inside of the back cover.
  7. Nextbook 8 Speaker Replacement: paso 7, imagen 1 de 1
    • Remove the two 0.116 inch screws holding the speaker assembly in place.
  8. Nextbook 8 Speaker Replacement: paso 8, imagen 1 de 1
    • Carefully pry the speaker off of the back cover with a spudger.
    • Note: There is glue holding the speaker to the back cover, so it will take some work to get it off.
  9. Nextbook 8 Speaker Replacement: paso 9, imagen 1 de 1
    • Use a desoldering tool to remove the solder holding the red and black speaker wires to the motherboard.
    • If you do not have a desoldering tool, you can use a solder gun to remove the old solder.
    • Caution: Soldering guns get extremely hot.
  10. Nextbook 8 Speaker Replacement: paso 10, imagen 1 de 1
    • Use the soldering gun to solder the new speaker wires to the motherboard where the original wires were connected.
    • Make sure that you connect the red wire to the positive terminal on the right, and the black wire to the negative terminal on the left.
Conclusión
Una persona más ha completado esta guía.
Dylan Wiese
Miembro Desde 03/11/15
1,871 Reputación
5 Guías creadas
Equipo
Colorado Springs, Team 5-1, Panko Spring 2015 Miembro de Colorado Springs, Team 5-1, Panko Spring 2015
UCCS-PANKO-S15S5G1
Miembros de 3
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 1,372
