Saltar al contenido principal
Nextbook 8 Camera Replacement
Qué necesitas
  1. Nextbook 8 Camera Replacement, Battery: paso 1, imagen 1 de 2 Nextbook 8 Camera Replacement, Battery: paso 1, imagen 2 de 2
    • Use the plastic opening tool to remove the back cover. Carefully slide the tool between the front glass and back cover.
    • Slide the tool along the edge to work the back cover off.
    • It helps to have an extra tool to stick in the gap and keep the back cover separated from the glass as you slide the other tool.
  2. Nextbook 8 Camera Replacement: paso 2, imagen 1 de 2 Nextbook 8 Camera Replacement: paso 2, imagen 2 de 2
    • Remove the tape covering the motherboard.
    • Remove the silver tape holding the white ribbon cables to the battery.
  3. Nextbook 8 Camera Replacement: paso 3, imagen 1 de 2 Nextbook 8 Camera Replacement: paso 3, imagen 2 de 2
    • Use a spudger to carefully disconnect the battery connector from the motherboard.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  4. Nextbook 8 Camera Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Use a spudger to lift up the black bar on the two ZIF connectors located above the battery.
    • Pull the ribbon cables out of the connectors with tweezers or two fingers.
  5. Nextbook 8 Camera Replacement: paso 5, imagen 1 de 2 Nextbook 8 Camera Replacement: paso 5, imagen 2 de 2
    • Using the flat end of a spudger, carefully work the spudger under the battery, lifting it off of the device.
    • The battery is very malleable, so do not try to pull it off all at once.
  6. Nextbook 8 Camera Replacement, Camera: paso 6, imagen 1 de 1
    • Slowly pull up masking tape by pulling down from the top.
    • Be careful because both the front and rear cameras are attached to each other.
  7. Nextbook 8 Camera Replacement: paso 7, imagen 1 de 1
    • Peel the bottom part of the masking tape off to reveal the ribbon connector.
  8. Nextbook 8 Camera Replacement: paso 8, imagen 1 de 1
    • Pull both camera lenses out of the holes.
  9. Nextbook 8 Camera Replacement: paso 9, imagen 1 de 1
    • Use a spudger to disconnect the two camera lenses from the device.
    • Carefully lift the black connector to release the cameras.
  10. Nextbook 8 Camera Replacement: paso 10, imagen 1 de 1
    • Pull both camera lenses out of the ribbon connector.
Conclusión
Dylan Wiese
Miembro Desde 03/11/15
1,871 Reputación
5 Guías creadas
Equipo
Colorado Springs, Team 5-1, Panko Spring 2015 Miembro de Colorado Springs, Team 5-1, Panko Spring 2015
UCCS-PANKO-S15S5G1
Miembros de 3
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 1,308
