Saltar al contenido principal
Nextbook 8 Battery Replacement
Qué necesitas
  1. Nextbook 8 Battery Replacement, Battery: paso 1, imagen 1 de 2 Nextbook 8 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Use the plastic opening tool to remove the back cover. Carefully slide the tool between the front glass and back cover.
    • Slide the tool along the edge to work the back cover off.
    • It helps to have an extra tool to stick in the gap and keep the back cover separated from the glass as you slide the other tool.
  2. Nextbook 8 Battery Replacement: paso 2, imagen 1 de 2 Nextbook 8 Battery Replacement: paso 2, imagen 2 de 2
    • Remove the tape covering the motherboard.
    • Remove the silver tape holding the white ribbon cables to the battery.
  3. Nextbook 8 Battery Replacement: paso 3, imagen 1 de 2 Nextbook 8 Battery Replacement: paso 3, imagen 2 de 2
    • Use a spudger to carefully disconnect the battery connector from the motherboard.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  4. Nextbook 8 Battery Replacement: paso 4, imagen 1 de 1
    • Use a spudger to lift up the black bar on the two ZIF connectors located above the battery.
    • Pull the ribbon cables out of the connectors with tweezers or two fingers.
  5. Nextbook 8 Battery Replacement: paso 5, imagen 1 de 2 Nextbook 8 Battery Replacement: paso 5, imagen 2 de 2
    • Using the flat end of a spudger, carefully work the spudger under the battery, lifting it off of the device.
    • The battery is very malleable, so do not try to pull it off all at once.
Conclusión
22 personas más completaron esta guía.
Dylan Wiese
Miembro Desde 03/11/15
1,853 Reputación
5 Guías creadas
Equipo
4 comentarios
Very helpful and well made.
Quentin Freed - Contestar
Where can I buy the battery???
scruff67 - Contestar
Check Ebay. That's where I'm headed right now.
Tina Carey -
im having connection issues i cant find any wifi period
crusher309 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 38
Todo El Tiempo: 42,138
