Saltar al contenido principal
Newport HT70 Plus Ventilator Air Intake Filter Replacement
Qué necesitas
  1. Newport HT70 Plus Ventilator Air Intake Filter Replacement, Air intake Filter: paso 1, imagen 1 de 1
    • Make sure that the Ventilator is turned OFF. The power switch is located in the back side of the ventilator.
    • Remove the Power Cord.
  2. Newport HT70 Plus Ventilator Air Intake Filter Replacement: paso 2, imagen 1 de 3 Newport HT70 Plus Ventilator Air Intake Filter Replacement: paso 2, imagen 2 de 3 Newport HT70 Plus Ventilator Air Intake Filter Replacement: paso 2, imagen 3 de 3
    • Locate the right panel of the Ventilator.
    • Remove the Air O2 mixer by rotating it counterclockwise, and then pull the mixer out.
  3. Newport HT70 Plus Ventilator Air Intake Filter Replacement: paso 3, imagen 1 de 1
    • Remove the two thumbscrews by twisting then counterclockwise.
    • Remove the filter cover. Use a prying tool if needed.
  4. Newport HT70 Plus Ventilator Air Intake Filter Replacement: paso 4, imagen 1 de 2 Newport HT70 Plus Ventilator Air Intake Filter Replacement: paso 4, imagen 2 de 2
    • Replace the old filter with the new one.
    • Once replaced, place back the Filter cover.
    • Screw the thumbscrews back into place, fastening them clockwise.
  5. Newport HT70 Plus Ventilator Air Intake Filter Replacement: paso 5, imagen 1 de 1
    • Run a Circuit Check before you install the air O2 mixer back into place.
    • Place back the air O2 mixer by adjusting the flanges into the proper position. And then rotate the air mixer clockwise to lock into place.
Conclusión
Una persona más ha completado esta guía.
Jorge Castillo
Miembro Desde 04/10/20
201 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S7-G5, Paton Spring 2020 Miembro de Cal Poly, Team S7-G5, Paton Spring 2020
CPSU-PATON-S20S7G5
Miembros de 3
6 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 422
