Saltar al contenido principal
NeuTab N9 Battery Replacement
Qué necesitas
  1. NeuTab N9 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off your device before beginning these steps.
    • Insert the plastic opening tool into the seam between the screen and the back of the tablet. Move the opening tool along the seam until the back of the tablet releases.
  2. NeuTab N9 Battery Replacement: paso 2, imagen 1 de 1
    • Insert plastic spudger underneath the edges of the battery to pry it up and detach the adhesive.
  3. NeuTab N9 Battery Replacement: paso 3, imagen 1 de 3 NeuTab N9 Battery Replacement: paso 3, imagen 2 de 3 NeuTab N9 Battery Replacement: paso 3, imagen 3 de 3
    • Completely remove the battery from the device by desoldering the red and black wires from the motherboard.
    • Follow these instructions if you do not already know how to desolder.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 310
