Saltar al contenido principal
NeuTab N7 Pro Speaker Replacement
Qué necesitas
  1. NeuTab N7 Pro Speaker Replacement, Speaker: paso 1, imagen 1 de 1
    • Power off your device before beginning disassembly.
    • Insert plastic opening tool and pry back case away from the device, slowly moving the plastic opening tool along the device.
  2. NeuTab N7 Pro Speaker Replacement: paso 2, imagen 1 de 2 NeuTab N7 Pro Speaker Replacement: paso 2, imagen 2 de 2
    • The speaker is attached to the back cover of the device.
    • Hold positive and negative wires as close as possible to the speaker. Use small plastic spudger and fingers to simultaneously lift speaker from cover.
  3. NeuTab N7 Pro Speaker Replacement: paso 3, imagen 1 de 3 NeuTab N7 Pro Speaker Replacement: paso 3, imagen 2 de 3 NeuTab N7 Pro Speaker Replacement: paso 3, imagen 3 de 3
    • Use a soldering gun to remove the positive and negative wires connecting the battery to the circuit board.
    • For a complete guide on how to solder, click here.
    • Be sure not to touch both the positive and negative terminal at the same time.
Conclusión
Una persona más ha completado esta guía.
Travis McLean
Miembro Desde 02/09/16
322 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 7-1, Cheng Spring 2016 Miembro de USF Tampa, Team 7-1, Cheng Spring 2016
USFT-CHENG-S16S7G1
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 248
