Saltar al contenido principal
NeuTab N7 Pro Camera Replacement
Qué necesitas
  1. NeuTab N7 Pro Camera Replacement, Camera: paso 1, imagen 1 de 1
    • Power off your device before beginning disassembly
    • Insert plastic opening tool and pry back case away, slowly moving the plastic opening tool along the device.
  2. NeuTab N7 Pro Camera Replacement: paso 2, imagen 1 de 1
    • Locate the camera unit and note where it is attached to the motherboard.
    • Use a black nylon spudger to remove the adhesive holding it onto to the motherboard.
    • Metal tools can puncture an unprotected battery, potentially causing a fire. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device.
  3. NeuTab N7 Pro Camera Replacement: paso 3, imagen 1 de 2 NeuTab N7 Pro Camera Replacement: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use a black nylon spudger or tweezers to release the connector holding the camera ribbon cable in place.
    • Carefully pull the ribbon cable out, removing the camera from the motherboard.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team 7-1, Cheng Spring 2016 Miembro de USF Tampa, Team 7-1, Cheng Spring 2016
USFT-CHENG-S16S7G1
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 220
