Saltar al contenido principal
NeuTab N7 Pro Battery Replacement
Qué necesitas
  1. NeuTab N7 Pro Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Power off your device before beginning disassembly.
    • Insert plastic opening tool and pry back case away from the device, slowly moving the plastic opening tool along the device.
  2. NeuTab N7 Pro Battery Replacement: paso 2, imagen 1 de 1
    • Follow the red and black wires from the battery to where they are soldered to the motherboard.
    • Warning: Use caution when handling a soldering iron to avoid injury or damage.
    • Use a soldering iron to separate the positive and negative wires from the motherboard.
    • For a complete guide on how to solder, click here.
  3. NeuTab N7 Pro Battery Replacement: paso 3, imagen 1 de 2 NeuTab N7 Pro Battery Replacement: paso 3, imagen 2 de 2
    • Insert plastic spudger under the battery and slide back and forth, separating the battery from the case.
Conclusión
3 personas más completaron esta guía.
Eric Fiske
Miembro Desde 02/09/16
430 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 7-1, Cheng Spring 2016 Miembro de USF Tampa, Team 7-1, Cheng Spring 2016
USFT-CHENG-S16S7G1
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 2,011
