Qué necesitas
Herramienta utilizada en este paso:iFixit Precision 4 mm Screwdriver Bit$2.99
Remove all of the 8 screws and the bottom panel should pop off.
Remove the screw with a Philips J1 driver.
Try to remove the cables by hand or if you really can't, then use a spudger to carefully pry them up.
After removing the screw and the cables, you can safely remove the network card.
Una persona más ha completado esta guía.
