Introducción
By removing the case you will be able to install a capacitor or an antenna.
Partes
No se requieren partes.
  1. Rotate the device so that the bottom is facing up.
    • Rotate the device so that the bottom is facing up.
  2. Lift up all four rubber pads on the bottom of the router with the plastic opening tool.
    • Lift up all four rubber pads on the bottom of the router with the plastic opening tool.
    • Be careful not to pull the rubber pads all the way out when lifting as they are difficult to reinsert.
    • Unscrew the four 11.8 mm T-8 torx screws from the bottom of the router.
    • Lift the bottom casing straight up from the router.
Conclusión
Una persona más ha completado esta guía.
Ryan Murphy
Miembro Desde 03/10/11
482 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 21-24, Maness Fall 2011 Miembro de Cal Poly, Team 21-24, Maness Fall 2011
CPSU-MANESS-F11S21G24
4 Miembros
6 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 5
Todo El Tiempo: 1,203
