Saltar al contenido principal
Netgear Arlo Battery Replacement
Qué necesitas
  1. Netgear Arlo Battery Replacement, Battery: paso 1, imagen 1 de 3 Netgear Arlo Battery Replacement, Battery: paso 1, imagen 2 de 3 Netgear Arlo Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Locate unlock switch on underside of camera and unlock it by sliding it.
    • Once unlocked, slide the cover out and up to open the battery housing.
  2. Netgear Arlo Battery Replacement: paso 2, imagen 1 de 1
    • Remove all 4 of the 3.0 Volt batteries from the battery housing.
  3. Netgear Arlo Battery Replacement: paso 3, imagen 1 de 1
    • Inspect prongs at the bottom of the battery housing to ensure that they are not bent or broken before replacing the batteries.
Conclusión
Una persona más ha completado esta guía.
Connor Krampen
Miembro Desde 01/08/18
399 Reputación
3 Guías creadas
Equipo
IUPUI, Team S1-G1, Freund Spring 2018 Miembro de IUPUI, Team S1-G1, Freund Spring 2018
IUPUI-FREUND-S18S1G1
2 Miembros
6 Guías creadas
2 comentarios
i am having a problem charging my arlo pro device
JOSEPH J RUTHERFORD - Contestar
I am having a problem with one of my cameras not recognizing the batteries. I replace the battery and it says that it’s low. I’ve tried the same battery on another one of my cameras and it has a full life of energy. I am out of warranty but wanted to know if maybe I can take take it somewhere to get fixed and where???
lawendolina - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 16
Ultimos 30 días: 62
Todo El Tiempo: 6,950
