Saltar al contenido principal
Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement
Qué necesitas
  1. Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement, Case: paso 1, imagen 1 de 3 Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement, Case: paso 1, imagen 2 de 3 Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement, Case: paso 1, imagen 3 de 3
    • Unscrew the two 3.0 mm Phillips #00 screws on the bottom of the camera.
    • Open the battery compartment on the bottom by pushing the switch marked in orange to the side and pushing the bottom of the camera back, sliding it open.
  2. Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement: paso 2, imagen 1 de 2 Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement: paso 2, imagen 2 de 2
    • Remove the bottom piece of the case over the battery compartment by placing a plastic opening tool underneath the edge of the case and prying it up.
    • Unscrew the four 3.0 mm Phillips #00 screws on the outside of the battery pocket.
  3. Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement: paso 3, imagen 1 de 2 Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement: paso 3, imagen 2 de 2
    • When facing the camera lens, the left panel of the case will be removed first (more steps are needed for the right panel).
    • Place the plastic opening tool between the two pieces of the case and pry them apart from the bottom.
    • Gently pull the side of the case off as it comes loose.
  4. Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement: paso 4, imagen 1 de 2 Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement: paso 4, imagen 2 de 2
    • Unscrew the smaller 3.0 mm Phillips #00 screw in the center on the back of the device.
    • Flip the camera over and unscrew the center 3.0 mm Phillips #00 screw above the SYNC button.
  5. Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement: paso 5, imagen 1 de 2 Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement: paso 5, imagen 2 de 2
    • Using the plastic opening tool, gently pry the right panel from the device.
    • Replace either side of the plastic case as needed.
  6. Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement, Camera/Lens: paso 6, imagen 1 de 3 Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement, Camera/Lens: paso 6, imagen 2 de 3 Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement, Camera/Lens: paso 6, imagen 3 de 3
    • Unscrew the four 4.0 mm Phillips #00 screws on either side of the transparent case.
    • Separate the transparent half of the case from the white half.
    • Only separate the two halves enough for them to be apart. The flat ribbon cable is short and its connection is delicate.
  7. Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement: paso 7, imagen 1 de 2 Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement: paso 7, imagen 2 de 2
    • Lift the small thin black rectangular latch that covers the connectors of the flat ribbon cable.
    • The latch is very flat, so use a finger nail or a spudger to lift it. Do not use any sharp edge like a knife as it will likely damage the device!
    • With the latch lifted, the cable will pull away freely as you separate the white half from the transparent half.
  8. Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement: paso 8, imagen 1 de 3 Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement: paso 8, imagen 2 de 3 Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement: paso 8, imagen 3 de 3
    • Repeat the same process as in Step 6 to release the flat ribbon cable from the black rectangular latch
    • Unscrew the six black 3.0 mm Phillips #00 screws that hold the black motherboard on.
    • Release the clip at the bottom left corner of the black motherboard by pinching the wings at either side of the clip.
    • Be sure that the transparent case or the black motherboard are being held or resting on a surface so that neither falls when the clip is released.
  9. Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement: paso 9, imagen 1 de 3 Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement: paso 9, imagen 2 de 3 Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement: paso 9, imagen 3 de 3
    • Remove the black plastic that contains the camera from its place.
    • Discard and replace this part as needed.
  10. Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement, Infrared LED and Motion Sensor Motherboard: paso 10, imagen 1 de 1
    • Remove the three 3mm Phillips #000 screws.
  11. Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement: paso 11, imagen 1 de 2 Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement: paso 11, imagen 2 de 2
    • Pull the infrared LED and motion sensor mother board out of the device.
    • Replace this as needed.
Conclusión
Equipo
UMass Dartmouth, Team S2-G4, Peak Fall 2018 Miembro de UMass Dartmouth, Team S2-G4, Peak Fall 2018
UMASSD-PEAK-F18S2G4
3 Miembros
10 Guías creadas
Un comentario
Do you know the pinout to the ir led
Atrain ley - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 1,289
