Introducción
Replacing the battery on your Nest couldn't be easier. The only tools required are tweezers, a Phillips #0 screwdriver, Phillips #2 screwdriver, and the opening tool
Qué necesitas
Grasp the display's outer ring with your fingers and pull directly away while rotating clockwise to remove the thermostat from the wall.
Go to the electrical panel and turn off the circuit to make sure no power is running to the thermostat.
Once the power is off, disconnect the Y1, G, R, W1, C, and OB wires.
