Saltar al contenido principal
Nest Thermostat E Battery Replacement
Qué necesitas
  1. Nest Thermostat E Battery Replacement, Base Plate: paso 1, imagen 1 de 1
    • Grasp the display's outer ring with your fingers and pull directly away while rotating clockwise to remove the thermostat from the wall.
    • Go to the electrical panel and turn off the circuit to make sure no power is running to the thermostat.
    • Once the power is off, disconnect the Y1, G, R, W1, C, and OB wires.
    • Remember the placement of each wire for reassembly.
  2. Nest Thermostat E Battery Replacement: paso 2, imagen 1 de 1
    • Remove the two 1 ¼” drywall screws holding the base display and base plate in the wall using a Phillips #2 screwdriver.
    • Remove the base plate and base display.
  3. Nest Thermostat E Battery Replacement: paso 3, imagen 1 de 1
    • Pry the base display off of the baseplate using an iFixit opening tool.
  4. Nest Thermostat E Battery Replacement, Battery: paso 4, imagen 1 de 1
    • Remove the four 6 mm screws using a Phillips #0 screwdriver.
    • The two smaller screws go around the pin connector and the two larger screws go by the outside bezel.
  5. Nest Thermostat E Battery Replacement: paso 5, imagen 1 de 1
    • Grab the pin connector and gently pull up to remove the thermostat backplate from the thermostat.
  6. Nest Thermostat E Battery Replacement: paso 6, imagen 1 de 1
    • Remove the four grey 6 mm screws and remove them along with the two pull tabs.
  7. Nest Thermostat E Battery Replacement: paso 7, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Grasp the orange tab with tweezers and gently pull the ribbon cable directly away from the motherboard.
  8. Nest Thermostat E Battery Replacement: paso 8, imagen 1 de 1
    • Flip the display over and the battery casing will fall from the base.
    • Alternatively, you can grab the four metal triangles and pull up lightly.
  9. Nest Thermostat E Battery Replacement: paso 9, imagen 1 de 1
    • Disconnect the battery connection identifiable by the black, yellow, and red wire.
    • Pull down the two pull tabs on the battery.
    • Grasp the battery with your fingers.
    • Pull gently directly away from the display to unplug the battery from the display motherboard.
    • Removing the battery will require breaking the existing adhesive seal. The new battery will come with a new adhesive seal to be placed on the motherboard.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 25
Ultimos 30 días: 73
Todo El Tiempo: 1,223
