Qué necesitas
Remove the Protect from it’s backplate by twisting counterclockwise on the device until it releases.
Unscrew the backplate.
Battery operated: Fully remove the backplate screws.
Hardwired: Slightly remove the backplate screws and twist the backplate.
Place the backplate on the wall.
Battery Operated: Screw in the backplate.
Hardwired: Twist the backplate so it locks into place and snug the screws
1ST Generation: Twist clockwise until it clicks into place
2ND Generation: Twist clockwise until it grips and adjust to fit the wall or ceiling of wall mounted.
