Introducción
When replacing the base motherboard, removal from the wall is necessary and power to the thermostat must be turned off. The tools required are the blue opening tools, spudger, and a #0 Phillips screwdriver.
Qué necesitas
Grasp the display's metal outer ring with your fingers and pull directly away from the wall, leaving the base behind.
Disconnect all wires from the grey spring-loaded connectors. This can be done using your fingers.
Remove the two 40mm screws from the base of the thermostat using a #0 Phillips screw driver.
Unsnap the base from the trim plate (if used) using a plastic opening tool.
Turn the base over.
Remove the four 6 mm screws from the back of the base using a #0 Phillips screwdriver.
Pry the base mother board open from the side using a plastic opening tool.
Pry the baseboard from the bottom using the flat end of a spudger.
6 personas más completaron esta guía.
8 comentarios
Where can we purchase replacement parts?
i want the baseboard.. where i can buy? pls help...
