Saltar al contenido principal
Nest Dropcam Pro Mounting Clips Replacement
Qué necesitas
  1. Nest Dropcam Pro Mounting Clips Replacement, Outer Case: paso 1, imagen 1 de 1
    • Press in the mounting clips on each side of the case to remove the camera from the mount.
  2. Nest Dropcam Pro Mounting Clips Replacement: paso 2, imagen 1 de 2 Nest Dropcam Pro Mounting Clips Replacement: paso 2, imagen 2 de 2
    • Using a Philips #0 screwdriver, remove the four 3 mm screws.
  3. Nest Dropcam Pro Mounting Clips Replacement: paso 3, imagen 1 de 2 Nest Dropcam Pro Mounting Clips Replacement: paso 3, imagen 2 de 2
    • Lift the front of the case slowly, as there is an antenna cable attached to the motherboard.
    • Carefully disconnect the antenna cable from the motherboard. You will feel this cable "pop" out of place when disconnected.
  4. Nest Dropcam Pro Mounting Clips Replacement, Mounting Clips: paso 4, imagen 1 de 2 Nest Dropcam Pro Mounting Clips Replacement, Mounting Clips: paso 4, imagen 2 de 2
    • Using a Philips #0 screwdriver, remove the four 4 mm screws that are attaching the mounting clips to the case.
  5. Nest Dropcam Pro Mounting Clips Replacement: paso 5, imagen 1 de 1
    • Lift the mounting clips away from the case.
Conclusión
David Foens
Miembro Desde 09/03/15
893 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 15-4, Blackwell Fall 2015 Miembro de USF Tampa, Team 15-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G4
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 1,244
