Saltar al contenido principal
Nest Dropcam Pro Motherboard Replacement
Qué necesitas
  1. Nest Dropcam Pro Motherboard Replacement, Outer Case: paso 1, imagen 1 de 1
    • Press in the mounting clips on each side of the case to remove the camera from the mount.
  2. Nest Dropcam Pro Motherboard Replacement: paso 2, imagen 1 de 2 Nest Dropcam Pro Motherboard Replacement: paso 2, imagen 2 de 2
    • Using a Philips #0 screwdriver, remove the four 3 mm screws.
  3. Nest Dropcam Pro Motherboard Replacement: paso 3, imagen 1 de 2 Nest Dropcam Pro Motherboard Replacement: paso 3, imagen 2 de 2
    • Lift the front of the case slowly, as there is an antenna cable attached to the motherboard.
    • Carefully disconnect the antenna cable from the motherboard. You will feel this cable "pop" out of place when disconnected.
  4. Nest Dropcam Pro Motherboard Replacement, Motherboard: paso 4, imagen 1 de 2 Nest Dropcam Pro Motherboard Replacement, Motherboard: paso 4, imagen 2 de 2
    • Insert a spudger tool under the micro-USB port and lift to separate the motherboard from the back case.
  5. Nest Dropcam Pro Motherboard Replacement: paso 5, imagen 1 de 2 Nest Dropcam Pro Motherboard Replacement: paso 5, imagen 2 de 2
    • Pull the motherboard away from the back case.
    • Unplug the red and black cable connecting the motherboard to the back case.
  6. Nest Dropcam Pro Motherboard Replacement: paso 6, imagen 1 de 2 Nest Dropcam Pro Motherboard Replacement: paso 6, imagen 2 de 2
    • Using a Philips #0 screwdriver, remove the four 2 mm screws.
  7. Nest Dropcam Pro Motherboard Replacement: paso 7, imagen 1 de 2 Nest Dropcam Pro Motherboard Replacement: paso 7, imagen 2 de 2
    • Lift the lens and LED assembly away from the motherboard.
    • Unplug the yellow and white cable from the motherboard.
Conclusión
7 personas más completaron esta guía.
David Foens
Miembro Desde 09/03/15
893 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 15-4, Blackwell Fall 2015 Miembro de USF Tampa, Team 15-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G4
3 Miembros
12 Guías creadas
7 comentarios
where we can get the mother board to replace
fercervantes - Contestar
I need this too
kundimberi -
Where can I get the motherboard
xtogamba - Contestar
Can't find it either. Silly to write an entire article for credit if parts arent actually available.
Bruce Weissman - Contestar
searched for the MB online?? Why no mention of where to get it??
anonymous 6761 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 18
Todo El Tiempo: 8,734
