Saltar al contenido principal
Nest Dropcam Pro LEDs Replacement
Qué necesitas
  1. Nest Dropcam Pro LEDs Replacement, Outer Case: paso 1, imagen 1 de 1
    • Press in the mounting clips on each side of the case to remove the camera from the mount.
  2. Nest Dropcam Pro LEDs Replacement: paso 2, imagen 1 de 2 Nest Dropcam Pro LEDs Replacement: paso 2, imagen 2 de 2
    • Using a Philips #0 screwdriver, remove the four 3 mm screws.
  3. Nest Dropcam Pro LEDs Replacement: paso 3, imagen 1 de 2 Nest Dropcam Pro LEDs Replacement: paso 3, imagen 2 de 2
    • Lift the front of the case slowly, as there is an antenna cable attached to the motherboard.
    • Carefully disconnect the antenna cable from the motherboard. You will feel this cable "pop" out of place when disconnected.
  4. Nest Dropcam Pro LEDs Replacement, Motherboard: paso 4, imagen 1 de 2 Nest Dropcam Pro LEDs Replacement, Motherboard: paso 4, imagen 2 de 2
    • Insert a spudger tool under the micro-USB port and lift to separate the motherboard from the back case.
  5. Nest Dropcam Pro LEDs Replacement: paso 5, imagen 1 de 2 Nest Dropcam Pro LEDs Replacement: paso 5, imagen 2 de 2
    • Pull the motherboard away from the back case.
    • Unplug the red and black cable connecting the motherboard to the back case.
  6. Nest Dropcam Pro LEDs Replacement: paso 6, imagen 1 de 2 Nest Dropcam Pro LEDs Replacement: paso 6, imagen 2 de 2
    • Using a Philips #0 screwdriver, remove the four 2 mm screws.
  7. Nest Dropcam Pro LEDs Replacement: paso 7, imagen 1 de 2 Nest Dropcam Pro LEDs Replacement: paso 7, imagen 2 de 2
    • Lift the lens and LED assembly away from the motherboard.
    • Unplug the yellow and white cable from the motherboard.
  8. Nest Dropcam Pro LEDs Replacement, LEDs: paso 8, imagen 1 de 2 Nest Dropcam Pro LEDs Replacement, LEDs: paso 8, imagen 2 de 2
    • Using a Philips #0 screwdriver, remove the four 2mm screws.
  9. Nest Dropcam Pro LEDs Replacement: paso 9, imagen 1 de 3 Nest Dropcam Pro LEDs Replacement: paso 9, imagen 2 de 3 Nest Dropcam Pro LEDs Replacement: paso 9, imagen 3 de 3
    • Peel off the paper seal holding the Lens and LEDs together.
    • Disconnect the red and white wire from the bottom board.
  10. Nest Dropcam Pro LEDs Replacement: paso 10, imagen 1 de 2 Nest Dropcam Pro LEDs Replacement: paso 10, imagen 2 de 2
    • Using a de-soldering tool, disconnect the LEDs from the motherboard.
    • If you don't know how to solder, check out How To Solder and Desolder Connections.
    • Soldering irons are extremely hot and can burn you if you touch them!
    • If you hold the soldering iron tip at the same spot for too long, it can strip the metal from the plastic board. You may not be able to solder wire to that point again.
Conclusión
David Foens
Miembro Desde 09/03/15
893 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 15-4, Blackwell Fall 2015 Miembro de USF Tampa, Team 15-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G4
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 13
Todo El Tiempo: 1,456
