Saltar al contenido principal
Nest Dropcam Pro Camera Lens Replacement
Qué necesitas
  1. Nest Dropcam Pro Camera Lens Replacement, Outer Case: paso 1, imagen 1 de 1
    • Press in the mounting clips on each side of the case to remove the camera from the mount.
  2. Nest Dropcam Pro Camera Lens Replacement: paso 2, imagen 1 de 2 Nest Dropcam Pro Camera Lens Replacement: paso 2, imagen 2 de 2
    • Using a Philips #0 screwdriver, remove the four 3 mm screws.
  3. Nest Dropcam Pro Camera Lens Replacement: paso 3, imagen 1 de 2 Nest Dropcam Pro Camera Lens Replacement: paso 3, imagen 2 de 2
    • Lift the front of the case slowly, as there is an antenna cable attached to the motherboard.
    • Carefully disconnect the antenna cable from the motherboard. You will feel this cable "pop" out of place when disconnected.
  4. Nest Dropcam Pro Camera Lens Replacement, Motherboard: paso 4, imagen 1 de 2 Nest Dropcam Pro Camera Lens Replacement, Motherboard: paso 4, imagen 2 de 2
    • Insert a spudger tool under the micro-USB port and lift to separate the motherboard from the back case.
  5. Nest Dropcam Pro Camera Lens Replacement: paso 5, imagen 1 de 2 Nest Dropcam Pro Camera Lens Replacement: paso 5, imagen 2 de 2
    • Pull the motherboard away from the back case.
    • Unplug the red and black cable connecting the motherboard to the back case.
  6. Nest Dropcam Pro Camera Lens Replacement: paso 6, imagen 1 de 2 Nest Dropcam Pro Camera Lens Replacement: paso 6, imagen 2 de 2
    • Using a Philips #0 screwdriver, remove the four 2 mm screws.
  7. Nest Dropcam Pro Camera Lens Replacement: paso 7, imagen 1 de 2 Nest Dropcam Pro Camera Lens Replacement: paso 7, imagen 2 de 2
    • Lift the lens and LED assembly away from the motherboard.
    • Unplug the yellow and white cable from the motherboard.
  8. Nest Dropcam Pro Camera Lens Replacement, Camera Lens: paso 8, imagen 1 de 2 Nest Dropcam Pro Camera Lens Replacement, Camera Lens: paso 8, imagen 2 de 2
  9. Nest Dropcam Pro Camera Lens Replacement: paso 9, imagen 1 de 3 Nest Dropcam Pro Camera Lens Replacement: paso 9, imagen 2 de 3 Nest Dropcam Pro Camera Lens Replacement: paso 9, imagen 3 de 3
    • Peel off the paper seal holding the Lens and LEDs together.
    • Disconnect the red and white wire from the bottom board.
  10. Nest Dropcam Pro Camera Lens Replacement: paso 10, imagen 1 de 2 Nest Dropcam Pro Camera Lens Replacement: paso 10, imagen 2 de 2
    • Lift up the foam cover to reveal a second screw underneath.
    • Using a Philips #0 screwdriver, remove the two 3 mm screws.
  11. Nest Dropcam Pro Camera Lens Replacement: paso 11, imagen 1 de 1
    • With the screws gone, lift the camera lens away from the remaining components.
Conclusión
2 personas más completaron esta guía.
David Foens
Miembro Desde 09/03/15
893 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 15-4, Blackwell Fall 2015 Miembro de USF Tampa, Team 15-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G4
3 Miembros
12 Guías creadas
2 comentarios
Where do you get replacement lens?
Jim Fischer - Contestar
good morning , is there any store on the USA where i can send my drop camera ti get fix? it fell and doesn't want to broadcast any image.
andres - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 21
Todo El Tiempo: 3,748
