Introducción
This guide is used to replace the camera lens of the Nest Dropcam Pro. Make sure the device is unplugged before opening.
Qué necesitas
Press in the mounting clips on each side of the case to remove the camera from the mount.
Insert a spudger tool under the micro-USB port and lift to separate the motherboard from the back case.
2 personas más completaron esta guía.
2 comentarios
Where do you get replacement lens?
