Introducción
The Nest Cam's speaker is responsible for producing sound and is an important part of the system, if your Nest Cam's audio is muffled or completely absent, the speaker may need to be replaced. This guide will help walk you through the steps of replacing a faulty speaker.
Qué necesitas
Remove the four 6 mm screws from the back panel with the J000 Phillips head screwdriver.
Una persona más ha completado esta guía.
4 comentarios
where can I buy the new replacement speaker part?
I’m curious as well if anyone has found where to obtain replacement/repair parts. Should be simple enough if we can determine the part number of the speaker.. suppose I’ll tear one down real quick to see.
Looking at the speaker without thermal coverings looks like it just has some sound information. “8 ohm 0.5 w”. Next line, “1742 (space) 1”. Third line, “+ S -”.
Looks like electrical info of the speaker. I’ll keep looking!
