Saltar al contenido principal
Nest Cam Speaker Replacement
Qué necesitas
  1. Nest Cam Speaker Replacement, Speaker: paso 1, imagen 1 de 1
    • Remove the four 6 mm screws from the back panel with the J000 Phillips head screwdriver.
    • We suggest designated areas to keep track of all screws.
  2. Nest Cam Speaker Replacement: paso 2, imagen 1 de 1
    • Open the back panel completely to expose the speaker indicated by the red circle.
  3. Nest Cam Speaker Replacement: paso 3, imagen 1 de 3 Nest Cam Speaker Replacement: paso 3, imagen 2 de 3 Nest Cam Speaker Replacement: paso 3, imagen 3 de 3
    • Remove old speaker gently with a spudger.
    • When placing the new speaker in make sure the prongs are facing the right direction and will connect with the two connector points on the motherboard.
Conclusión
Una persona más ha completado esta guía.
Jade Weiss
Miembro Desde 02/24/16
662 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 1-1, Leahy Spring 2016 Miembro de USF Tampa, Team 1-1, Leahy Spring 2016
USFT-LEAHY-S16S1G1
7 Miembros
10 Guías creadas
4 comentarios
where can I buy the new replacement speaker part?
Bradley Kang - Contestar
Anyone find out the answer to Bradley's question?
Ravi - Contestar
I’m curious as well if anyone has found where to obtain replacement/repair parts. Should be simple enough if we can determine the part number of the speaker.. suppose I’ll tear one down real quick to see.
Christopher Monge - Contestar
Looking at the speaker without thermal coverings looks like it just has some sound information. “8 ohm 0.5 w”. Next line, “1742 (space) 1”. Third line, “+ S -”.
Looks like electrical info of the speaker. I’ll keep looking!
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 23
Todo El Tiempo: 2,680
