Saltar al contenido principal
Nest Cam Outdoor S Plastic Camera Cover Replacement
Qué necesitas
  1. Nest Cam Outdoor S Plastic Camera Cover Replacement, Plastic Camera Cover: paso 1, imagen 1 de 2 Nest Cam Outdoor S Plastic Camera Cover Replacement, Plastic Camera Cover: paso 1, imagen 2 de 2
    • Wedge a spudger between the black front panel and the white outer shell.
    • Slide the spudger around the edge of the panel to pop it off.
  2. Nest Cam Outdoor S Plastic Camera Cover Replacement: paso 2, imagen 1 de 1
    • Remove the four small screws from the plastic camera cover.
  3. Nest Cam Outdoor S Plastic Camera Cover Replacement: paso 3, imagen 1 de 1
    • Disconnect the microphone cable to separate the motherboard from the main camera unit.
  4. Nest Cam Outdoor S Plastic Camera Cover Replacement: paso 4, imagen 1 de 2 Nest Cam Outdoor S Plastic Camera Cover Replacement: paso 4, imagen 2 de 2
    • Remove the plastic camera cover from the device.
Conclusión
Phelix Gaudette
Miembro Desde 10/28/21
275 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 4-6, Gulbrandsen Fall 2021 Miembro de UMass Dartmouth, Team 4-6, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G6
2 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 26
Todo El Tiempo: 514
