Qué necesitas
Wedge a spudger between the black front panel and the white outer shell.
Slide the spudger around the edge of the panel to pop it off.
Pry the plastic cover away from the motherboard at the plastic clips using a spudger.
2 personas más completaron esta guía.
2 comentarios
Can you replace the corn to the actual camera
Can you replace the corn to actual camera
