Saltar al contenido principal
Nest Cam Outdoor S Internal Camera Replacement
Qué necesitas
  1. Nest Cam Outdoor S Internal Camera Replacement, Plastic Camera Cover: paso 1, imagen 1 de 2 Nest Cam Outdoor S Internal Camera Replacement, Plastic Camera Cover: paso 1, imagen 2 de 2
    • Wedge a spudger between the black front panel and the white outer shell.
    • Slide the spudger around the edge of the panel to pop it off.
  2. Nest Cam Outdoor S Internal Camera Replacement: paso 2, imagen 1 de 1
    • Remove the four small screws from the plastic camera cover.
  3. Nest Cam Outdoor S Internal Camera Replacement: paso 3, imagen 1 de 1
    • Disconnect the microphone cable to separate the motherboard from the main camera unit.
  4. Nest Cam Outdoor S Internal Camera Replacement: paso 4, imagen 1 de 2 Nest Cam Outdoor S Internal Camera Replacement: paso 4, imagen 2 de 2
    • Remove the plastic camera cover from the device.
  5. Nest Cam Outdoor S Internal Camera Replacement, Internal Camera: paso 5, imagen 1 de 1
    • Pry the plastic cover away from the motherboard at the plastic clips using a spudger.
  6. Nest Cam Outdoor S Internal Camera Replacement: paso 6, imagen 1 de 1
    • Remove the four mounting screws from the motherboard.
  7. Nest Cam Outdoor S Internal Camera Replacement: paso 7, imagen 1 de 1
    • Disconnect the yellow camera cable from the motherboard.
    • Remove the camera from the device.
Conclusión
2 personas más completaron esta guía.
Skylar DeVoe
Miembro Desde 10/28/21
235 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 4-6, Gulbrandsen Fall 2021 Miembro de UMass Dartmouth, Team 4-6, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G6
2 Miembros
4 Guías creadas
2 comentarios
Can you replace the corn to the actual camera
Cathy Willis - Contestar
Can you replace the corn to actual camera
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 39
Todo El Tiempo: 1,645
