Saltar al contenido principal
Nest Cam Outdoor S Battery Replacement
Qué necesitas
  1. Nest Cam Outdoor S Battery Replacement, Plastic Camera Cover: paso 1, imagen 1 de 2 Nest Cam Outdoor S Battery Replacement, Plastic Camera Cover: paso 1, imagen 2 de 2
    • Wedge a spudger between the black front panel and the white outer shell.
    • Slide the spudger around the edge of the panel to pop it off.
  2. Nest Cam Outdoor S Battery Replacement: paso 2, imagen 1 de 1
    • Remove the four small screws from the plastic camera cover.
  3. Nest Cam Outdoor S Battery Replacement: paso 3, imagen 1 de 1
    • Disconnect the microphone cable to separate the motherboard from the main camera unit.
  4. Nest Cam Outdoor S Battery Replacement: paso 4, imagen 1 de 2 Nest Cam Outdoor S Battery Replacement: paso 4, imagen 2 de 2
    • Remove the plastic camera cover from the device.
  5. Nest Cam Outdoor S Battery Replacement, Battery: paso 5, imagen 1 de 2 Nest Cam Outdoor S Battery Replacement, Battery: paso 5, imagen 2 de 2
    • Wedge a nylon spudger between the white outer shell and the battery.
    • Slowly pull the battery away from the plastic camera cover.
    • The battery is only held on with glue.
Conclusión
Una persona más ha completado esta guía.
Phelix Gaudette
Miembro Desde 10/28/21
275 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 4-6, Gulbrandsen Fall 2021 Miembro de UMass Dartmouth, Team 4-6, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G6
2 Miembros
4 Guías creadas
2 comentarios
Do you have the P/N of the battery??
Richard K Yabuki - Contestar
Where to buy a replacement battery?
Ted McKenna - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 60
Ultimos 30 días: 241
Todo El Tiempo: 6,432
