Saltar al contenido principal
Nest Cam Motherboard Replacement
Qué necesitas
  1. Nest Cam Motherboard Replacement, Motherboard: paso 1, imagen 1 de 1
    • Remove the four 6 mm screws from the back panel with the JIS 000 screwdriver.
    • We suggest designated areas to keep track of all screws.
  2. Nest Cam Motherboard Replacement: paso 2, imagen 1 de 3 Nest Cam Motherboard Replacement: paso 2, imagen 2 de 3 Nest Cam Motherboard Replacement: paso 2, imagen 3 de 3
    • Open the back panel completely to expose the inside of the Nest Cam.
    • Using the tweezers, disconnect the red and black mic cable from the motherboard.
  3. Nest Cam Motherboard Replacement: paso 3, imagen 1 de 2 Nest Cam Motherboard Replacement: paso 3, imagen 2 de 2
    • Remove the two 4 mm screws with the JIS 000 screwdriver from the center.
    • Disconnect the black Wi-Fi cable from the motherboard with the tweezers.
  4. Nest Cam Motherboard Replacement: paso 4, imagen 1 de 3 Nest Cam Motherboard Replacement: paso 4, imagen 2 de 3 Nest Cam Motherboard Replacement: paso 4, imagen 3 de 3
    • Use a plastic spudger to lift the motherboard slightly up to expose and disconnect the white cable and the yellow/white IR cable with tweezers.
    • Then use the spudger or a finger to lift the motherboard completely up and off.
    • When installing the new motherboard ensure that all wires are reconnected before securing.
Conclusión
5 personas más completaron esta guía.
Khiry Jones
Miembro Desde 02/29/16
156 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 1-1, Leahy Spring 2016 Miembro de USF Tampa, Team 1-1, Leahy Spring 2016
USFT-LEAHY-S16S1G1
7 Miembros
10 Guías creadas
4 comentarios
where can I get a MoBo for my drop cam?
mikelebp1 - Contestar
where can i find a motherboard replacement?
Steve - Contestar
I have a Nest Outdoor IQ Camera. The Camera is Dead. Would love to Replace the Motherboard. Where can I get one ???
pmwenc@aol.com - Contestar
same here, no where to be found online
chantalder - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 15
Ultimos 30 días: 38
Todo El Tiempo: 24,301
