Saltar al contenido principal
Nest Cam Mic Cable Replacement
Qué necesitas
  1. Nest Cam Mic Cable Replacement, Mic Cable: paso 1, imagen 1 de 1
    • Remove the four 6 mm screws from the back panel with the J000 Phillips head screwdriver.
    • We suggest designated areas to keep track of all screws.
  2. Nest Cam Mic Cable Replacement: paso 2, imagen 1 de 3 Nest Cam Mic Cable Replacement: paso 2, imagen 2 de 3 Nest Cam Mic Cable Replacement: paso 2, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Open the back panel completely to expose the inside of the Nest Cam.
    • Using the tweezers, disconnect the red and black mic cable from the motherboard.
  3. Nest Cam Mic Cable Replacement: paso 3, imagen 1 de 1
    • Holding the back panel firmly, use a spudger to pry off the small plastic panel holding the mic cable in place.
    • Use a heat gun to melt the glue keeping the mic cable in place and then remove it.
    • During reassembly this plastic piece may need to be glued back on to ensure the mic cable stays in place on the back panel.
Conclusión
Una persona más ha completado esta guía.
Jade Weiss
Miembro Desde 02/24/16
662 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 1-1, Leahy Spring 2016 Miembro de USF Tampa, Team 1-1, Leahy Spring 2016
USFT-LEAHY-S16S1G1
7 Miembros
10 Guías creadas
3 comentarios
Thank you for this look inside the device. In the Nest settings there is a way to turn off the microphone, but anyone with access can turn it back on. I'm going to use this guide to unplug the microphone and permanently (but reversibly) disable it.
Bruce MacDonald - Contestar
Yes, by accessing the settings either via the app, or the website. Device options will all you to control the mic recording, or notifications if you just don't want to know when it picks up audio. Each app has its own settings on my devices, I think, but don't quote me on that one.
Be He - Contestar
Good job.
Do you have any idea if the cam doesn't restart?
Thanks.
Summer
summer - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 26
Todo El Tiempo: 3,708
