Saltar al contenido principal
Nest Cam IQ Lens Replacement
Qué necesitas
  1. Nest Cam IQ Lens Replacement, Lens: paso 1, imagen 1 de 1
    • To soften the adhesive holding the camera together, heat up the edges of the glass lens using a heated iOpener on the device. Alternatively, you can use a heat gun to loosen the adhesive.
    • Leave the Opener on the glass lens for two minutes.
    • Be careful not to burn yourself while handling the hot iOpener. For more information on the Opener, use the iOpener Instructions Guide.
  2. Nest Cam IQ Lens Replacement: paso 2, imagen 1 de 1
    • Use an opening tool to split apart the glass lens from the body.
    • Be careful to not break the glass when prying from the body.
  3. Nest Cam IQ Lens Replacement: paso 3, imagen 1 de 1
    • Place a suction cup on the glass lens that you heated up with the iOpener.
    • Press down on the suction cup to create a seal, and pull up with force to create a separation between the glass lens and the body.
    • Pull off the glass lens using the suction cup.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 23
Todo El Tiempo: 379
