Saltar al contenido principal
Nest Cam IQ Camera Replacement
Qué necesitas
  1. Nest Cam IQ Camera Replacement, Camera: paso 1, imagen 1 de 1
    • To soften the adhesive holding the camera together, heat up the edges of the glass lens using a heated iOpener on the device. Alternatively, you can use a heat gun to loosen the adhesive.
    • Leave the iOpener on the glass lens for two minutes.
    • Be careful not to burn yourself while handling the hot iOpener. For more information on the iOpener, use the iOpener Instructions Guide.
  2. Nest Cam IQ Camera Replacement: paso 2, imagen 1 de 1
    • Use an opening tool to split apart the glass lens from the body.
    • Be careful to not break the glass when prying from the body.
  3. Nest Cam IQ Camera Replacement: paso 3, imagen 1 de 1
    • Place a suction cup on the glass lens that you heated up with the iOpener.
    • Press down on the suction cup to create a seal, and pull up with force to create a separation between the glass lens and the body.
    • Pull off the glass lens using the suction cup.
  4. Nest Cam IQ Camera Replacement: paso 4, imagen 1 de 2 Nest Cam IQ Camera Replacement: paso 4, imagen 2 de 2
    • Carefully disconnect the flat black ribbon cable connecting the metal plate to the LED.
    • Remove the metal plate.
  5. Nest Cam IQ Camera Replacement: paso 5, imagen 1 de 2 Nest Cam IQ Camera Replacement: paso 5, imagen 2 de 2
    • Remove the five 9 mm TR6 Torx screws from the LED cover.
    • Pull off the LED cover.
    • As you remove the LED cover, be careful not to tear the flat black ribbon connecting the LED to the motherboard.
  6. Nest Cam IQ Camera Replacement: paso 6, imagen 1 de 3 Nest Cam IQ Camera Replacement: paso 6, imagen 2 de 3 Nest Cam IQ Camera Replacement: paso 6, imagen 3 de 3
    • Carefully disconnect the flat black ribbon cable connecting the LED to the motherboard.
    • Remove the LED cover.
  7. Nest Cam IQ Camera Replacement: paso 7, imagen 1 de 1
    • Remove the two 7 mm TR6 Torx screws securing the camera.
    • Carefully pull out the camera.
    • As you remove the camera, be careful not to tear the flat black ribbon connecting the camera to the motherboard.
  8. Nest Cam IQ Camera Replacement: paso 8, imagen 1 de 2 Nest Cam IQ Camera Replacement: paso 8, imagen 2 de 2
    • Carefully disconnect the flat black ribbon cable connecting the camera to the motherboard.
    • Remove the camera.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 139
