Saltar al contenido principal
Nespresso Pixie Internal Diffuser Replacement
Qué necesitas
  1. Nespresso Pixie Internal Diffuser Replacement, Internal Diffuser: paso 1, imagen 1 de 1
    • Unplug the machine from any outlets.
    • Remove the water tank by pressing the top button and pulling outwards.
    • Make sure there is no fluid left in any part of the machine.
  2. Nespresso Pixie Internal Diffuser Replacement: paso 2, imagen 1 de 2 Nespresso Pixie Internal Diffuser Replacement: paso 2, imagen 2 de 2
    • Use a Torx T5 screwdriver to detach the lever of the machine on both sides.
  3. Nespresso Pixie Internal Diffuser Replacement: paso 3, imagen 1 de 1
    • Remove the drip tray using your hand.
  4. Nespresso Pixie Internal Diffuser Replacement: paso 4, imagen 1 de 1
    • Use your hand to remove the black drip tray grill behind the drip tray.
  5. Nespresso Pixie Internal Diffuser Replacement: paso 5, imagen 1 de 2 Nespresso Pixie Internal Diffuser Replacement: paso 5, imagen 2 de 2
    • Use a Torx T4 screwdriver to unscrew each screw on the faceplates.
    • Remove the faceplate using a metal spudger.
    • Be sure to start in both corners to separate the pieces.
  6. Nespresso Pixie Internal Diffuser Replacement: paso 6, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Locate the two springs in each top right corner and use a set of tweezers to remove them.
    • Be sure to set the machine in an enclosed container when this is done so as to not to lose the springs.
  7. Nespresso Pixie Internal Diffuser Replacement: paso 7, imagen 1 de 1
    • Take off the white plastic bits using a metal spudger.
  8. Nespresso Pixie Internal Diffuser Replacement: paso 8, imagen 1 de 2 Nespresso Pixie Internal Diffuser Replacement: paso 8, imagen 2 de 2
    • Remove the clear plastic bits using a metal spudger.
    • Be sure to pull it out using the hole in which it is indented.
  9. Nespresso Pixie Internal Diffuser Replacement: paso 9, imagen 1 de 1
    • Use your hands to remove the cables that give power to the machine.
  10. Nespresso Pixie Internal Diffuser Replacement: paso 10, imagen 1 de 1
    • Use your hands to remove the water spout.
  11. Nespresso Pixie Internal Diffuser Replacement: paso 11, imagen 1 de 1
    • Seperate both halves of the machine using both a spudger and your hands.
    • Be sure to take your time and start in the middle. Note that it is incredibly well secured.
  12. Nespresso Pixie Internal Diffuser Replacement: paso 12, imagen 1 de 1
    • Use your hands to pull out the first lever housing in the spot shown in the picture.
  13. Nespresso Pixie Internal Diffuser Replacement: paso 13, imagen 1 de 1
    • Pull the brewing mechanism apart from the remaining plastic barrier.
    • Once it is separated, pull off the other lever housing in the same way as was described in the previous step.
  14. Nespresso Pixie Internal Diffuser Replacement: paso 14, imagen 1 de 2 Nespresso Pixie Internal Diffuser Replacement: paso 14, imagen 2 de 2
    • Use a spudger to unclip the clips holding the black case in place.
    • Pull the brewing chamber outwards from the machine and then pull it downwards to detach it.
  15. Nespresso Pixie Internal Diffuser Replacement: paso 15, imagen 1 de 2 Nespresso Pixie Internal Diffuser Replacement: paso 15, imagen 2 de 2
    • Pry off the clips holding the inner white chamber in place in the machine.
  16. Nespresso Pixie Internal Diffuser Replacement: paso 16, imagen 1 de 1
    • Use a spudger to take off your diffuser plate.
    • Insert your new diffuser plate.
Conclusión
Drew
Miembro Desde 11/05/23
253 Reputación
1 Guía escrita
Equipo
UMass Dartmouth, Team 2-2, Gulbrandsen Fall 2023 Miembro de UMass Dartmouth, Team 2-2, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G2
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 34
Ultimos 30 días: 115
Todo El Tiempo: 536
