Introducción
If your Nespresso Pixie is not brewing an adequate amount of coffee, or if you notice that liquid is blocked from flowing freely, your machine may be airlock at the brewing mechanism. Airlocking is when air becomes trapped in the Pixie's brewing spout system, which ultimately disrupts the brewing process. This can happen as the result of scale buildup or coffee grounds clogging the brewing spout. This guide will provide practical steps to resolve the issue.
Qué necesitas
Unplug the machine from any outlets.
Remove the water tank by pressing the top button and pulling outwards.
Apply steady pressure to both ends of the brewing chamber, pushing it in to extract the lever housing.
Remove the lever housing by gripping it with your hands and pulling it out.
After separating it, remove the other handle holder using the same method as outlined in the previous step.
Utilize a metal spudger to disengage the clips securing the black case in position.
Draw the brewing chamber outward from the machine, and then pull it downward to disconnect the brewing spout chamber.
Following the disconnection of the brewing spout chamber, the inner brewing spout will become visible.
To reassemble your device, please follow these instructions in reverse order.
