Saltar al contenido principal
Nespresso Pixie Brewing Spout Replacement
Qué necesitas
  1. Nespresso Pixie Brewing Spout Replacement, Brewing Spout: paso 1, imagen 1 de 2 Nespresso Pixie Brewing Spout Replacement, Brewing Spout: paso 1, imagen 2 de 2
    • Before beginning disassembly, make sure there is no fluid left inside the water tank or any capsule in the capsule’s chamber.
    • Unplug the machine from any outlets.
    • Remove the water tank by pressing the top button and pulling outwards.
  2. Nespresso Pixie Brewing Spout Replacement: paso 2, imagen 1 de 2 Nespresso Pixie Brewing Spout Replacement: paso 2, imagen 2 de 2
    • Use a T5 Torx screwdriver to unscrew both sides of the lever (metal handle) to prevent interference during disassembly.
    • Remove the metal handle by pulling it up.
  3. Nespresso Pixie Brewing Spout Replacement: paso 3, imagen 1 de 2 Nespresso Pixie Brewing Spout Replacement: paso 3, imagen 2 de 2
    • Remove the drip tray using your hand.
    • Remove the drip tray grill using your hands.
  4. Nespresso Pixie Brewing Spout Replacement: paso 4, imagen 1 de 2 Nespresso Pixie Brewing Spout Replacement: paso 4, imagen 2 de 2
    • Use a a Torx T5 screwdriver to unscrew the screws from each corner of both faceplates.
    • Remove the faceplate using a metal spudger.
    • Start in the corners and carefully separate them.
  5. Nespresso Pixie Brewing Spout Replacement: paso 5, imagen 1 de 3 Nespresso Pixie Brewing Spout Replacement: paso 5, imagen 2 de 3 Nespresso Pixie Brewing Spout Replacement: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Locate the two springs in each top right corner and remove them using precision tweezers.
    • Place your hand on the top to prevent the loss of springs and facilitate their retrieval.
    • Use your hand to remove the waterspout.
    • Remove white plastic bits using a screwdriver or metal spudger.
  6. Nespresso Pixie Brewing Spout Replacement: paso 6, imagen 1 de 3 Nespresso Pixie Brewing Spout Replacement: paso 6, imagen 2 de 3 Nespresso Pixie Brewing Spout Replacement: paso 6, imagen 3 de 3
    • Remove the clear plastic bits with a metal spudger.
    • Gently disconnect the power cables from the machine with your hands.
  7. Nespresso Pixie Brewing Spout Replacement: paso 7, imagen 1 de 2 Nespresso Pixie Brewing Spout Replacement: paso 7, imagen 2 de 2
    • Use a metal spudger tool and your hands to remove the outer shell.
    • Take your time during this step and initiate the process from the center, where the marker is located.
    • Note these pieces are securely fastened to the machine.
    • Using your hands, gently separate the plastic that is covering the coffee size buttons.
  8. Nespresso Pixie Brewing Spout Replacement: paso 8, imagen 1 de 3 Nespresso Pixie Brewing Spout Replacement: paso 8, imagen 2 de 3 Nespresso Pixie Brewing Spout Replacement: paso 8, imagen 3 de 3
    • Apply steady pressure to both ends of the brewing chamber, pushing it in to extract the lever housing.
    • Remove the lever housing by gripping it with your hands and pulling it out.
    • After separating it, remove the other handle holder using the same method as outlined in the previous step.
  9. Nespresso Pixie Brewing Spout Replacement: paso 9, imagen 1 de 3 Nespresso Pixie Brewing Spout Replacement: paso 9, imagen 2 de 3 Nespresso Pixie Brewing Spout Replacement: paso 9, imagen 3 de 3
    • Pull the brewing chamber cover outwards from the machine, then pull it downwards to detach.
    • Use your hands to pull the brewing mechanism apart from the remaining plastic barrier.
  10. Nespresso Pixie Brewing Spout Replacement: paso 10, imagen 1 de 3 Nespresso Pixie Brewing Spout Replacement: paso 10, imagen 2 de 3 Nespresso Pixie Brewing Spout Replacement: paso 10, imagen 3 de 3
    • Utilize a metal spudger to disengage the clips securing the black case in position.
    • Draw the brewing chamber outward from the machine, and then pull it downward to disconnect the brewing spout chamber.
    • Following the disconnection of the brewing spout chamber, the inner brewing spout will become visible.
  11. Nespresso Pixie Brewing Spout Replacement: paso 11, imagen 1 de 3 Nespresso Pixie Brewing Spout Replacement: paso 11, imagen 2 de 3 Nespresso Pixie Brewing Spout Replacement: paso 11, imagen 3 de 3
    • Utilize a metal spudger to disengage the clips securing the white inner brewing spout in position.
  12. Nespresso Pixie Brewing Spout Replacement: paso 12, imagen 1 de 2 Nespresso Pixie Brewing Spout Replacement: paso 12, imagen 2 de 2
    • Examine the coffee spout and the areas through which coffee passes to remove any trapped coffee grounds, scale, or debris, ensuring a clear pathway.
    • Clean the brewing spout thoroughly with a damp cloth, water, and mild soap to remove any remaining debris.
Conclusión
To reassemble your device, please follow these instructions in reverse order.
Jose B. Marin
Miembro Desde 11/06/23
305 Reputación
1 Guía escrita
Equipo
UMass Dartmouth, Team 2-2, Gulbrandsen Fall 2023 Miembro de UMass Dartmouth, Team 2-2, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G2
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 18
Ultimos 30 días: 92
Todo El Tiempo: 436
